Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2016 09 Eaton Logo196x65
Two Speeds Keep CTLs on Track
Sept. 27, 2016
Sponsored by Eaton
Compact track loaders (CTLs) have been the fastest-growing segment of the mobile equipment market since the start of the century. With broad, high-flotation rubber tracks, these machines operate on underfoot surfaces that challenge the stability of biggerwheeled machines. Buyers of CTLs, such as contractors, owner-operators, farmers, ranchers, and rental agencies, want faster and more powerful machines to increase productivity.
To achieve these goals, a current trend with CTLs is two-speed drives. This is because a typical CTL spends 40% of its time in high-speed mode (transporting and traveling) and 60% in lowspeed mode (digging and doing other high-torque work). The two-speed mode boosts productivity without the substantial cost of a continuously variable transmission.
Download FAQs on Two Speeds Keep CTLs on Track sponsored by Eaton to get the answers.
Plug-in pneumatic valves
April 3, 2005
VS Series plug-in subbase valves consist of a glandless spool and sleeve valve with a life of 200 million cycles and a soft seal spool valve offering high flow rates. Available...
March 18, 2009
Table of Contents
Feb. 6, 2024
