Master Bond manufactures industrial adhesives, sealants, and coatings with properties that are successfully used in a wide range of hydraulics, pneumatics, sensors, batteries, motors, and more.
154 Hobart St Hackensack, NJ 07601 United States of America
Master Bond’s wide-ranging product line of epoxies, silicones, UV curable and LED curable systems are reliable, come in convenient packaging and meet specialized criteria in applications for the power and motion industries.
More Info on Master Bond
Courtesy of Master Bond
Master Bond
Master Bond formulates innovative, high quality epoxy adhesives, sealants, coatings and potting/encapsulation compounds for high tech industries. Each system is designed to meet specific application needs and requirements for reliability and endurance. Compounds are formulated to withstand vibration and shock, resist chemicals, be electrically insulative, and more.
Established in 1976, today Master Bond formulates over 3,000 grades of epoxies, silicones, UV cures and other specialty adhesive systems, in a variety of standard and specialty packaging. Our experienced application engineers provide individual support to help determine the best adhesive for your application.
Master Bond EP62-1HTND is a two component epoxy system formulated for bonding and sealing applications requiring high temperature capability and chemical resistance, particularly...
Master Bond MasterSil 981-LO is a two-component silicone designed for high performance bonding, sealing, and encapsulating applications. It does not require air for curing. The...
One component, highly thermally conductive, silver filled epoxy, cures at 80-90°C Key Features Paste consistency Available in syringes and jars Unlimited working life, requires...
Master Bond UV26DCMed is a dual-cure epoxy system designed for medical applications. It utilizes UV light for the initial cure and heat to fully polymerize areas not directly ...
Two part epoxy with high thermal conductivity, electrically insulating, and low thermal resistance for bonding and sealing. Key Features Thermal conductivity exceeds 6...
Master Bond EP5LTE-100 is a one part, non-premixed and frozen epoxy with a very low coefficient of thermal expansion (CTE), high glass transition temperature (Tg), and extremely...
Master Bond Supreme 17HTMed is a one component, toughened epoxy system formulated for bonding and sealing across medical device applications. This single component material requires...
Master Bond EP55TCFL is engineered for applications demanding efficient heat dissipation and electrical insulation. Its small particle filler enables thin bond lines, reducing...
Master Bond UV16Med-FD is a one part, low viscosity, epoxy based UV curable system containing a fluorescent dye for identification. This feature enables visual inspection with...
Optically Clear, High Flexibility Silicone Meets NASA Low Outgassing Specifications Master Bond MasterSil 981-LO is a two component, addition cured silicone system designed for...
Premier die attach epoxy EP3HTSDA-2 features a very impressive thermal conductivity of 40-45 BTU•in/(ft²•hr•°F), substantially higher than other silver conductive epoxies. This...
Watch this demonstration to learn the step by step process of mixing a two part epoxy system, where Part A is a liquid and Part B is a powder. Epoxy system EP126 was used in this...
Master Bond EP4S-80 is a one component, silver filled epoxy for bonding, sealing and coating. This NASA low outgassing approved system cures at the low temperature of 80˚C and...
When determining the most effective adhesive to be used in opto-electronics, medical and other optic related industry applications, trade-offs of key characteristics should be...
Conductive bonding agents play a fundamental role in ensuring reliable electrical connectivity in many electromechanical assemblies designed to operate at the extremes of temperature...
Overview Master Bond UV10TKLO-2 is a one-component UV-curable system for high-performance bonding, sealing, and encapsulation applications. It meets NASA’s specifications...
Overview of EP30HT-LO Master Bond EP30HT-LO is a moderate-viscosity, two-component, epoxy system that can be cured at room temperature, or at elevated temperatures for a faster...
Overview of UV11-3Master Bond UV11-3 is a hard, super-abrasion-resistant coating system for various substrates. It can be cured readily by ultraviolet (UV) exposure at around ...
Master Bond formulates high-quality, innovative compounds for the laser, optics, and photonics industries. Our goal is to help engineers meet specific requirements for their bonding...
Master Bond EP29LPSPND-3 is a two component, non-drip epoxy compound with a paste consistency that can be used for bonding and sealing applications. The system is electrically...
Master Bond LED415DC90Med is a one component, dual cure adhesive system designed for high-speed manufacturing of medical electronic devices. It cures rapidly without oxygen inhibition...
Master Bond has launched EP53TC, a two-component epoxy designed for bonding, sealing, coating, and small potting applications where efficient heat dissipation is crucial. The ...
Master Bond Supreme 121AOND is a toughened epoxy system for bonding and sealing applications. It is a two component, heat curing system with a thixotropic paste consistency. Supreme...
Master Bond EP64 is a two-component, vacuum-compatible epoxy system engineered for bonding, sealing, and coating applications. It features a high glass transition temperature...
Master Bond EP6STC-80 is a one component, non-frozen, silver filled epoxy engineered for bonding, sealing, and coating applications requiring exceptional thermal and...
Master Bond UV26DCMed is a one component, dual cure adhesive system designed for medical device assembly. It is specifically engineered for reusable devices that require ...
Master Bond EP54TC is a two-component epoxy engineered for heat sink bonding and thermal management applications where efficient heat transfer is critical. Featuring the highest...
December 19, 2025 - Hackensack, NJ - Master Bond Supreme 10HTLV is a one part, non-frozen, heat cured epoxy formulated for demanding structural bonding applications. This...
MasterSil 800Med is a one component, moisture curing silicone specifically designed for medical device manufacturing. It passes ISO 10993-5 testing for non-cytotoxicity, confirming...
Master Bond LED422DC90 is a one component, nanosilica filled dual cure adhesive system engineered for high-speed fixturing and bonding of opaque substrates. This unique "side-...
Master Bond EP3HTSDA-2Med is a true one component epoxy that is not pre-mixed and frozen. It offers an easy dispensing profile with an exceptionally long working life at room ...
Developed for medical device applications, Master Bond EP21LSCL-2Med is a two component non-cytotoxic epoxy for bonding, sealing, coating and potting. While most if not all epoxies...
Master Bond EP3HT-LO is a single component, non-premixed & frozen, heat cured epoxy, with an unlimited working life at room temperature. This system passes ASTM E595 tests...
As medical devices have evolved through technological advancements, they have become more complex in both their design and materials of construction. Medical-grade biocompatible...
Master Bond EP21ARHTND-2 is a two-part epoxy adhesive, designed to withstand prolonged exposure to a wide range of chemicals. “The system’s chemical resistance was...
