Kyntronics
Kyntronics produces hybrid actuation and servo power systems.
6565 Davis Industrial Parkway
Solon, Ohio 44139
United States of America
440-220-5990
(US only) 855-596-8765
More Info on Kyntronics
Kyntronics is a developer of hybrid actuation and servo power systems which combine hydraulic and electromechanical technologies to achieve the benefits of each.
Articles
386681259 © Hrishchenko Oleksandr | Dreamstime.com
Test bench with hoses, valves and other components
Learn the critical factors to consider when choosing whether to use hydraulic, electromechanical or hybrid actuation technology for a test system.
222079801 © Evgeniy Parilov | Dreamstime.com
Close up on a hydraulic cylinder on a blue machine
Machine performance requirements, budget and workforce knowledge are among the first aspects to consider when deciding whether to use a hydraulic, pneumatic or electric actuation...
37729441 © Stepan Popov | Dreamstime.com
Automated Bottling Line
The high-performance demands now placed on low-force automation applications is causing manufacturers to consider using hybrid linear actuators.
441006271 © Miroslav Milda | Dreamstime.com
Linear Actuation System
Learn how load alignment and system design play a critical role in ensuring the reliability of linear actuators.
72172446 © Stepan Popov | Dreamstime.com
Sheet Metal Stamping Machine
Hybrid actuators combine hydraulic power and electric control to provide an energy-efficient, leak-free, and durable solution for press machinery and other applications.
Compared to a variable-displacement pump driven by a constant-speed motor, a pump powered by a variable-speed drive can cut energy costs, lower heat and noise generation, and ...
A self-contained modular actuator continues the trend of driving a hydraulic pump with a variable speed motor. But this one departs from convention with patent-pending features...
Kyntronics Categories
Additional content from Kyntronics
Hydraulic, pneumatic and electric motion control technologies on display at Automate 2026 demonstrate the important role all three play in today's automation systems.
