Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2009 85078 Mobileequi 00000057434
Mobile equipment cooling
Dec. 10, 2009
Edited By Mary C. Gannon T-BAR technology incorporates radiator, hydraulic oil, and charge air coolers into a custom-designed package. Modules are manufactured with Alloy 1100 aluminum micro channel and bars. Core sizes range in height/width ...
T-BAR technology incorporates radiator, hydraulic oil, and charge air coolers into a custom-designed package. Modules are manufactured with Alloy 1100 aluminum micro channel and bars. Core sizes range in height/width from 1 to 6 ft2. Depths vary from 114 to 512 in. Cooling capability ranges from 20 to 550 hp engines. They are rated to 300 psi maximum static pressure, and 300°F maximum inlet temperatures. They are compatible with petroleum and mineral oils, oil/water emulsion, phosphate ester, water/ethylene glycol, and heated air.
Thermal Transfer Products, (262) 554-8330, www.thermaltransfer.com
