Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 03 01 2009 8407210000psipu 00000056303
10,000-psi pump
April 1, 2009
The new Model 1810 pump joins the company’s line of triplex positive- displacement pumps. It delivers lowpulsation flow of 3 gpm at 10,000 psi. The 1810 pump has a low unswept volume for maximum volumetric efficiency and a ...
It delivers lowpulsation flow of 3 gpm at 10,000 psi. The 1810 pump has a low unswept volume for maximum volumetric efficiency and a compact footprint for both portable and stationary installation. Features include stainless-steel body, solid ceramic plungers, high-strength plunger rods, oversized bearings, and chrome-moly crankshaft for durability. Other features include an optional 15,000-psi rupture disc, regulating relief valve, and pressure gage.
Cat Pumps
1681 94th Lane NE
Minneapolis, MN 55449
(763) 780- 5440
catpumps.com
As a general rule of thumb, charge pump displacement should be at least 10% of the combined displacement of the transmission pump and motor.
March 6, 2018
Compared to a variable-displacement pump driven by a constant-speed motor, a pump powered by a variable-speed drive can cut energy costs, lower heat and noise generation, and ...
