Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Pneprods0102png 00000000374
Washdown valves
April 3, 2005
Clean Line Series CL03 pneumatic valves have an IP69K rating for high-pressure washdown to 1,450 psi — no protective cabinet is needed. Flow to 0.85 CV. Multi-pin connection or serial communication options for major protocols. Consist of ...
Clean Line Series CL03 pneumatic valves have an IP69K rating for high-pressure washdown to 1,450 psi — no protective cabinet is needed. Flow to 0.85 CV. Multi-pin connection or serial communication options for major protocols. Consist of individual subbases in inch or ISO-G ports and can be expanded to 16 valves in single valve increments. One system can handle up to 32 different pressures.
Bosch Rexroth Corp.
(859) 254-8031,
www.boschrexroth-us.com
