A new line of electronic pedal controls is designed for long life in off-highway and on-highway applications. It uses two non-contacting, hall-effect sensors instead of potentiometers, for durability and long life. Independent circuits ensure ...
A new line of electronic pedal controls is designed for long life in off-highway and on-highway applications. It uses two non-contacting, hall-effect sensors instead of potentiometers, for durability and long life. Independent circuits ensure system is failsafe. PWM or analog output meets SAE J1843 standards. Dual return springs provide redundancy required in FMVSS 124. Includes 3-bolt, floor-mount configuration.
