Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2011 86957 Hydraulicp 00000059606
Hydraulic power pack
Feb. 16, 2011
By Mary C. Gannon, Senior Associate Editor KA compact hydraulic power pack supplies pressure in machine tools for short term and intermittent service. It consists of a pump, tank and integrated submerged motor. When fitted with radial piston pump, ...
By Mary C. Gannon,
KA compact hydraulic power pack supplies pressure in machine tools for short term and intermittent service. It consists of a pump, tank and integrated submerged motor. When fitted with radial piston pump, it generates operating pressures to 10,000 psi; gear pump achieves maximum of 2900 psi. Dual-flow pump is used in case the pump has to supply consumers with different flow and pressure levels. It generates maximum flow of 5.2 gpm. Tank volume can be increased from 1.3 to 6.6 gal, depending on tank extensions.
HAWE Hydraulics, (704) 509-1599, www.hawehydraulics.com
