Cylinders press side rollers against block during notch-filling to remove swelling of pages caused by double-fan gluing.
Brushing. A brush cleans off dust and chips from milling and sanding.
Double-fan gluing. In manual operations, the most critical aspect of fan gluing is the need to apply uniform pressure on the block when it is being deflected in either direction to induce fanning of the pages. The Ultrabind machine solves this problem in a unique manner whereby the rotating glue roller first presses against the book block, then is articulated to move in a curvilinear path against the spine of the stationary block. This produces a pageby- page fanning and tipping action to assure penetration of adhesive between pages. On the return stroke, glue is applied to the opposite face of the pages.
Notch filling. An extra layer of glue is applied at this station to fill the notches in the spine. Sensors detect the front and rear edges of the block prior to the application of glue.
Squeezing. To improve the quality of rebinding, book thickness is gauged and side rollers are pressed pneumatically against the pages to remove any swelling induced by the double-fan gluing. This also holds the pages tight together, preventing glue in the notches from penetrating between the pages.
Lining. This procedure begins to install the protective material that will cover the glued spine. Backlining material is fed in, matched to the leading edge of the book, and coated with a thin film of glue. As the book passes, a softrubber pneumatic roller presses the lining onto the book. Simultaneously, the roller forms backlining flaps on each side of the spine prior to folding the lining against the book. When the trailing edge of the book is detected, the material strip is automatically cut off with a fast-response, pneumatically actuated knife.
Flap-folding. Backlining material is folded against the sides of the book in an innovative operation which pulls the backlining flaps over the sides without wrinkles to yield smooth, square, quality- bound volumes.
Unloading. At this final station, a pneumatic cylinder opens the clamp and the glued book drops a short distance onto a pneumatically powered platform. This platform gently lowers the book onto a curved chute for delivery to a conveyor belt or other pick-up mechanism below. For safety, a photoelectric sensor stops the operation if a book fails to leave the clamp.
Design engineer Ken Lines of Mekatronics and applications engineer Tarek El-Sawaf of Festo Corp., Hauppauge, N.Y., described this equipment.
