Eaton’s HLA system joins the company’s electric and plug-in hybrid systems for use on numerous truck models that are used by major fleets across the country.
The HLA system captures the trucks’ kinetic energy during braking to assist in launching and accelerating the vehicle. The HLA technology recovers up to 75% of the energy normally lost as heat by the vehicle’s brakes in the form of pressurized hydraulic fluid. This fluid is stored in an on-board accumulator until the driver next accelerates the vehicle, which reduces fuel consumption and wear on the engine. Users have reported significant reductions in maintenance costs. Because the HLA system provides significant regenerative braking during deceleration, foundation brake replacement cost can potentially be reduced by four times compared to a conventional truck.
In addition to the Crane option, Eaton’s HLA system has been commercially available on refuse chassis Model 320 sold by Peterbilt. Eaton expects to have 100 HLA trucks in service around the nation by the end of 2010.
Fleet testing continues
Bosch Rexroth’s Rochester Hills, Mich. facility continues to offer its hybrid system for testing. The City of Garland, Texas’ Environmental Waste Services Department recently began a long-term field test evaluation of Bosch Rexroth’s parallel Hydrostatic Regenerative Braking (HRB) system.
The test is sponsored by the Houston Advanced Research Center (HARC) through a grant from the Texas Environmental Research Consortium, with funding provided by the Texas Commission on Environmental Quality. It aims to significantly reduce exhaust emissions (such as nitrogen oxides and particulate matter), fuel consumption, and vehicle operating costs for fleets used in stop-and-go traffic. Successful performance may lead to wider adoption in refuse trucks in Garland and nationwide.
The vehicle is a Crane Carrier LET2 with a Heil Environmental CP Python Rapid Rail automated side loader body. Two identical trucks will be outfitted with data collection systems to evaluate and compare performance. The trucks will be subjected to braking, acceleration, route collection, and dynamometer testing to evaluate emissions.
The HRB system captures a portion of the kinetic energy normally lost as frictional heat during braking, storing it in the form of highly compressed gas for later use in assisting the engine in propelling the vehicle, reducing fuel consumption, wear on the brake system, and wear on the engine.
“We would like to see this important technology validated in the field so it can be commercially available soon to reduce emissions and save fuel. I believe that, like the electric hybrid passenger car, hybrid technologies, such as HRB, are the right solutions for this type of heavy-duty application,” said Dr. Yiqun Huang, HARC NTRD program director.
