Cloud Computing 62f410d28bc51
Cloud Computing Finalists
Aug. 15, 2022
Be sure to check out the other 2022 IDEA Awards category finalists.
Allen-Bradley ASEM 6300 Industrial Monitors
The Allen-Bradley ASEM 6300M industrial monitors help OEMs differentiate machines and meet a wide range of application needs. Several design options give OEMs freedom to customize monitors based on cost, performance, look and feel. Design options include stainless-steel for washdown, aluminum or edge-to-edge glass, single- and multi-touch, sizes from 8.4 to 24 in. in standard and widescreen. All have high-resolution displays. The monitors can display up to four tiles on one screen.
Rockwell Automation
Tri-Edge CDR Platform
Semtech’s Tri-Edge PAM4 CDR platform is optimized for optical interconnect in next generation 200G/400G data centers and Cloud applications, offering power savings up to 20% per optical link versus DSP technology. To meet demands placed on data center infrastructure by ever-evolving Cloud use cases, Semtech introduced production of its GN2558/GN2559 CDRs to enable advanced connectivity over multi-mode fiber, delivering a low-cost solution with the low power/latency analog signal processing to meet the demands of Cloud applications.
Semtech
