Noshok ∆P gauges
Expanded Range of ∆P Gauges
Nov. 28, 2018
1000 Series piston- and diaphragm-type differential pressure gauges have been re-engineered and expanded.
1000 Series piston- and diaphragm-type differential pressure gauges have been re-engineered and expanded. They are available in 2½-, 4½-, and, now, 6-in. dial sizes. They feature a rugged engineered plastic case and anodized aluminum and 316 stainless steel wetted parts. A shatter-resistant acrylic lens is standard on all sizes and models. They are also available with single- and dual-switch options, as well as a 4-20 mA transmitter option in a NEMA-4X IP65 plastic enclosure. A variety of mounting options, connections, and O-ring and diaphragm materials are available. Options include mounting holes, pipe mounting kits, reversed ports, and stainless steel tagging. Applications include back flow testing, heat exchangers, filter monitoring, flow indication, and level indication.
Noshok Inc., (440) 243-0888
