Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Spotlight0201jp 00000003170
Transfer barrier accumulators
June 2, 2005
Transfer barrier accumulators are designed for use with two different types of fluid to transfer pressure and a small amount of volume from one medium to another. Sizes from 1 qt. to 15 gal, up to 9000 psi. Shells are electroless nickel-plated ...
Transfer barrier accumulators are designed for use with two different types of fluid to transfer pressure and a small amount of volume from one medium to another. Sizes from 1 qt. to 15 gal, up to 9000 psi. Shells are electroless nickel-plated inside and out with all 316 stainless steel fluid ends. Buna N bladder and seals standard. SAE, NPT, split flange connections with elastomers optional.
Accumulators Inc.,
(713) 465-0202,
www.accumulators.com
