How to handle a Hot situation
Feb. 24, 2006
Most hydraulic systems generate substantial heat, so they can benefit from using a heat exchanger. Here's why and how.
Hydraulic systems can use either of two methods of load control: the energy-loss method, in which flow to the actuator is set by valving, or the volumecontrol method, in which a variabledisplacement pump regulates flow.
Most industrial hydraulic systems are designed using the energy-loss method. However, energy lost as heat can exceed that of the mechanical power produced by the system. For example, even well-designed electrohydraulic servovalve or proportional valve systems may convert 60 to 80% of input horsepower to heat.
Some hydraulic system heat is desirable to bring fluid up to operating temperature. Cold hydraulic oil has a higher viscosity than warm oil. So maintaining an operating temperature of 100° F would cause sluggish operation and excessive pressure drop in a system designed to operate at 140° F. When a system begins operation on a cold winter morning, for example, the oil should be allowed to warm until it reaches a temperature where heat is generated at the same rate as system heat radiating into the atmosphere or other cooling medium.
If heat generation exceeds the rate at which heat can be dissipated, the excess heat can initiate oil decomposition, form varnish on system component surfaces, and begin to deteriorate system seals. Excess heat sooner or later spells trouble for any hydraulic system. Too much heat breaks down oil, damages seals and bearings, and increases wear on pumps and other components. The solution to these problems is the inclusion of a properly sized heat exchanger as a component of the system.
Thermodynamics
Heat is a form of energy that migrates from one region to another when a temperature difference (gradient) exists between the regions. Heat naturally flows from the hotter region to the cooler one. The rate of heat transfer is important in determining how much can be removed from a system within a given time frame. As long as it has a higher heat transfer rate, a physically smaller heat exchanger can remove heat from a system faster than one that is much larger.
The defining equation for any heat exchanger is:
q = U X A X ΔT
where: q is the heat transfer rate, BTU/hr,
U is the overall heat transfer coeficient, BTU/hr-ft2-° F,
A is the heat transfer surface area, ft2, and
Δ is the fluid temperature difference, °F.
These three factors take varying forms, depending on the particular design of heat exchanger and the application involved. Inspecting the equation reveals that increasing any factor on the right increases heat transfer rate in direct proportion. Doubling the surface area in contact with the heated fluid doubles the heat transfer rate. Increasing temperature difference between the hydraulic oil and the coolant by 50% increases the heat transfer rate by 50%.
Heat dissipates from a fluid system through natural and forced convection. Natural convection occurs as heat moves from system components into the surrounding atmosphere because of the temperature gradient. In smaller hydraulic systems, temperatures generally are lower than in larger systems, and heat transfer from the oil to tubing and other component surfaces often provides sufficient cooling.
However, if natural convection cannot remove enough generated heat, a heat exchanger must be installed to control system temperature. The heat exchanger uses forced convection to remove heat. Another mode of heat transmission, radiation, may often occur, but its effect is small and usually can be ignored.
Tube-pass configurations
Heat exchangers are available in 1-, 2-, and 4-pass configurations, Figure 1. These multiple passes result from dividers in the bonnets that mate with segmenting bars on the tube sheets to initially force the cooling medium (water) through only a fraction of the tubes. This causes the water to flow one, two, or four times the length of the heat exchanger before it leaves the outlet.
Fluid can flow in laminar, transitional, and turbulent modes. When flow is laminar and at low velocities in a tube, there is little or no fluid movement immediately next to the tube wall. This layer of stagnant fluid hinders heat transfer and acts as insulation.
Faster, turbulent flow has no smooth velocity gradient. The jumbled, tumbled flow pattern can disrupt much of the stationary fluid film. Built-in obstructions to flow, called turbulators, disrupt laminar flow, thereby improving heat transfer. Although these obstructions to flow increase pressure drop through the heat exchanger, the improvement in heat transfer more than compensates for the higher pressure drop.
Water cooling
Shell-and-tube heat exchangers, Figure 2, have an outer flanged shell with end bonnets appropriately sealed to the shell ends. A precise pattern of tubing within the shell runs the length of the shell and terminates in end plates. Tube ends are fastened to the end plates, which seal each end of the shell. Cool water flows inside the tubes, and hot hydraulic oil flows around the tubes within the shell.
The tubes that make up the tube bundle, or core, are arranged in geometric tube bundle patterns (square or triangular centerline spacing when viewed from the tube ends) to help promote turbulent flow. The tubes run through several baffle plates that provide structural rigidity and create a maze through which the hot fluid must flow. This flow pattern enhances heat transfer by forcing the hot fluid to flow perpendicular to the tubes and promoting laminar flow. Many tube bundles for hydraulic applications are permanently sealed in the shell. Models with removable tube bundles are available but are more expensive and have different sealing conditions at the shell ends.
Air cooling
When the air sink is the choice to receive waste heat, a familiar air-to-oil heat exchanger, Figure 3, is used. Even though it radiates heat only to a small degree, it is often called a radiator instead of a convector. It convects heat and uses the same equation examined earlier to describe performance.
Hot oil passes through the tubes of these heat exchangers, and turbulators help break up laminar flow to promote efficient heat transfer from the fluid to the tube wall. The tube metals also have high thermal conductivity.
Stagnant air around tube exteriors presents a problem in the effort to increase heat transfer. Still air is a poor conductor and has a high thermal resistance that limits heat transfer. As might be supposed, increasing air flow over the tubes helps decrease this thermal resistance. The amount of decrease again depends on whether the air flow is laminar or turbulent. In either case, the air still inhibits heat transfer because it is not as good a conductor of heat as water or oil.
As with shell-and-tube heat exchangers, increasing the heat transfer surface area increases heat transfer capability. Fins, physically fastened to the tubes, increase surface area and, as an added benefit, help break up laminar air flow.
Newer designs
Shell-and-tube heat exchangers had been the mainstay of industry for decades. In the past twenty years, however, newer designs have been developed to increase effectiveness and provide equivalent heat transfer surface in a smaller envelope, while still reducing cost.
An extended-surface design adds many fins to the external sides of tubes. These fins provide more surface area and improve the heat transfer coefficient, thereby reducing the size of the heat exchanger over standard shell-andtube versions. However, because of the greater internal heat-transfer surface area, pressure drop is correspondingly greater than in older designs.
An extended-surface shell-andtube design is also available with a spring-loaded pressure-surge protector. If system pressure surges, a bypass valve opens to protect the tubes from damage.
Another newer heat exchanger design is the brazed-plate type. The heat-transfer surface consists of a series of stainless-steel plates, each stamped with a corrugated pattern designed for a combination of high strength, efficiency, and fouling resistance. The number and design of the plates vary according to the desired heat-transfer capacity. The plates are stacked together with thin sheets of copper or nickel between each plate. The plate pack, end plates, and connections are brazed together in a vacuum furnace to secure the plates together at the edges and at all contact points. Inlet and outlet connections are available in several different styles.
The brazed-plate heat exchanger is compact, rugged, and provides high heat transfer capability. Its heat-transfer surface area is concentrated in a very small volume. The corrugations in the plates induce turbulent flow to increase heat transfer and reduce fouling. A brazed-plate heat exchanger holds about one-eighth the liquid volume of a thermally comparable shelland-tube counterpart.
Normally, the hot and the cold fluids make only one pass through this exchanger. The incoming fluids are directed through alternate parallel channels created by the stacked channel plates. The single pass through the unit means the flow passage is as long as the heat exchanger is high. This short flow path offsets any pressure drop which is caused by the turbulation.
A plate-fin heat exchanger is characterized by its compact, lightweight,-and efficient design. It provides significantly more cooling per cubic inch than the other designs described thus far. Plate-fin heat exchangers consist of finned chambers separated by flat plates and route fluids through alternating hot and cold passages. Heat transfers through fins in the passageways, through a separator plate, and into the cold fluid through another set of fins, Figure 4.
The basic construction consists of alternate layers of fins and plates brazed together to provide a honeycomb structure that offers high resistance to vibration and shock. Because it is so efficient, lightweight, and has high structural integrity, it is frequently used in military andaviation hydraulic applications.
Another reason for using a platefin heat exchanger is that design flexibility is much greater with this type than with the others. Finned passage sizes are easily varied by changing fin heights. The number and width of finned passages are also easily varied as is the fin density. A plate-fin heat exchanger's size and shape can be customized to fit a particular envelope.
Application considerations
When determining the heat exchanger requirements of a hydraulic system, consider how much heat the system generates and what temperatures the oil and system components can tolerate. Determining hydraulic cooling needs can be confusing because heat generation may vary as a machine progresses through different cycles. Also, ambient temperatures may shift or heat generation may increase over time.
The first step in determining heat transfer requirements of a system is to know the temperature limits of the system fluid and components. This information is available from the respective suppliers.
Next, estimate total system heat output before building the system. To arrive at this value, many designers use the nominal percentage of input horsepower method. Using this method, heat is estimated to be a percentage of total system inefficiency, based on individual component inefficiencies, plumbing surface area, and past experience. The total of these percentages is multiplied by the input hp and converted to BTU/min, BTU/hr, or kW.
For example, a 300-hp hydraulic system is assigned an efficiency rating of 70% or 210 hp. The remaining 30%, 90 hp, is lost as heat. The 90 hp converts to 3,820 BTU/min or 229,200 BTU/hr, or 67.14 kW. After the system is built, heat rejection is determined by measuring the fluid temperature rise during system operation over a period of time. Temperature rise per unit of time and system capacity determine heat input.
To reduce their exposure to high pressures, heat exchangers should be installed in the tank return line to reduce their need to withstand high pressures. A bypass valve protects them from high pressure surges, such as those commonly experienced during cold starts. Bypass valves also can be specified based on fluid temperature. In this manner, fluid bypasses the heat exchanger until it reaches a predetermined temperature, which closes the bypass valve and routes fluid through the heat exchanger. An alternate piping method uses a separate circuit from the reservoir with a small pump to drive the oil through the heat exchanger. Filters often are incorporated into these side circuits, often called kidney loops.
Oil-to-air heat exchangers are most commonly used in mobile applications. Engine coolant is available for oil cooling, but the heat must eventually be removed into ambient air through the radiator. Some installations use a separate section of the radiator in front of the engine-driven fan for oil cooling.
When considering application and sizing of heat exchangers, the steady-state temperature of the hydraulic fluid and the time it takes to arrive at that temperature must be used. A heat exchanger manufacturer can assist with application and selection. When contacting the representative, be prepared to provide the following:
  • oil heat load in BTU/min
  • oil flow in gpm
  • maximum oil temperature
  • ambient air temperature during system operation
  • environmental contaminants that can affect the system
  • maximum allowable pressure drop.
If the heat exchanger is liquid cooled, the supplier will also need to know the cooling water inlet temperature and flow rate. Most manufacturers' literature includes examples, steps, and simplified equations to help size heat exchangers properly.
Now the heat exchanger choice can be made: will it be an air-or water-cooled version? Generally, air-cooled heat exchangers are more expensive than water-cooled ones on a per-unit basis, because on other than mobile applications, the air-cooled version requires a fan/motor package. Other considerations include:
  • electric costs to run the fan,
  • costs to purchase water, pump it, or perhaps treat it before use or after discharge,
  • fan noise and hot air exhaust,
  • clogged cooling surfaces if debris becomes airborne, and
  • vibration mounts and flexible piping.
A properly sized and applied heat exchanger can save time, money, and repair costs. Many hydraulic systems should not operate without one.
This information originally appeared in the Fluid Power Handbook & Directory. It was recently updated for this article by My Tran, engineering manager, Thermal Transfer Products, Racine, Wis. For more information, call (262) 554-8330, or visit www.thermasys.com
Sizing and selecting a heat exchanger to cool a mobile hydraulic system presents some real challenges. First, you have to come up with an accurate assessment of how much heat ...
March 14, 2017
Based on specific heat alone, water appears to be a superior hydraulic fluid to oil. Because it takes twice is much heat, to get the same quantity of water to the same temperature...
