Airtech fan-cooled units suit mobile and industrial applications where cooling requirements are remotely located, cooling water is unavailable or impractical, or where coolant is subject to freezing. All-aluminum vacuum brazed bar and plate ...
Airtech fan-cooled units suit mobile and industrial applications where cooling requirements are remotely located, cooling water is unavailable or impractical, or where coolant is subject to freezing. All-aluminum vacuum brazed bar and plate construction provides heat transfer efficiency in a compact, and light weight package. They are suitable for use as oil coolers and air aftercoolers. Eight model sizes provide a range of capacities in ac and dc versions.
Time-sensitive networking offers many advantages to industrial automation applications but certain factors need to be considered when implementing the technology.
