Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 45437 Prods B0102 00000020952
Product release: Oil coolers
Feb. 20, 2007
High-performance oil coolers feature T-Bar 100% brazed aluminum extruded tube core (no seams) that is capable of handling high flows and high viscosity fluids while the core is protected in a steel frame. Heat exchangers are available in seven ...
High-performance oil coolers feature T-Bar 100% brazed aluminum extruded tube core (no seams) that is capable of handling high flows and high viscosity fluids while the core is protected in a steel frame. Heat exchangers are available in seven sizes with maximum flow ratings from 20 to 500 gpm.
Thermal Transfer Products, Div. of API Heat transfer, (262) 554-8330, www.thermasys.com
