Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2008 83417 Balancegau 00000055423
Balance Gauge Kit
Dec. 16, 2008
Kit provides the hoses, fittings and a sturdy carrying case for quick system balancing. It is designed for use when several pressurized vessels must be pressure or flow balanced using a zero center differential pressure gauge. It is available ...
Kit provides the hoses, fittings and a sturdy carrying case for quick system balancing. It is designed for use when several pressurized vessels must be pressure or flow balanced using a zero center differential pressure gauge. It is available in many ranges and scales from ±1-in. water to ±100 psid. Options include bleed vent valves and several dial sizes.
Differential Pressure Plus Inc.
(203) 481-2545
www.differentialpressure.com
