Edited By Mary C. Gannon Tubomatic S77 swager crimps hoses into tight and articulate curves through the use of a frontal rift. It can crimp flexible hydraulic hoses up to 1 1/4 in. diameter. Electronic control allows for management of all working ...
Tubomatic S77 swager crimps hoses into tight and articulate curves through the use of a frontal rift. It can crimp flexible hydraulic hoses up to 1 1/4 in. diameter. Electronic control allows for management of all working parameters and cycles by means of an easily accessible user interface. Quick die changing is done by a tool that captures eight pieces simultaneously and positions them within the appropriate lodgings in the machine’s head in order to perform the crimping safely and easily. OP Srl - Hydraulic Hose & Tubing Processing Equipment, +39 030 3580401, www.op-srl.it
