Aeroquip GH810 Ice Champion spiral wire hose is engineered for low-temperature, high-pressure hydraulic applications. It is suitable for use in temperatures as low as –67°F, operating pressures to 6090 psi, and is available in -12 through -24 ...
Aeroquip GH810 Ice Champion spiral wire hose is engineered for low-temperature, high-pressure hydraulic applications. It is suitable for use in temperatures as low as –67°F, operating pressures to 6090 psi, and is available in -12 through -24 sizes and uses Aeroquip Global Spiral TTC crimp fittings that require no skiving. Hose meets DIN EN specifications, has a 4:1 safety ratio, and has been qualified to withstand 400,000 impulse cycles.
