Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 07 01 2011 87628 Tubecuttin 00000060284
Tube-cutting machine
July 14, 2011
Tube-cutting machine Edited By Catlin Nalley Unispeed USFL 24/37 allows preassembling DIN2353 rings and 37° flaring of hydraulic tubes up to 42-mm diameter and a maximum thickness of 4 mm. The machine is equipped with a double working level: ...
Unispeed USFL 24/37 allows preassembling DIN2353 rings and 37° flaring of hydraulic tubes up to 42-mm diameter and a maximum thickness of 4 mm. The machine is equipped with a double working level: an upper level for bends up to 180° and a lower one for standard tubes. It features electronic control and the ability for high volume production.
OP S.r.l Hydraulic Tubing Processing Machines
+39 030-3580401
http://bit.ly/HP711OPSrl
