Thermoplastic hydraulic hose
June 8, 2012
Piranhaflex 100R18, PF427 series hydraulic hose is suited for hydraulic applications with a constant rated working pressure of 3000 psi for each available ID size of ¼, 3⁄8, and ½ in. Typical uses include construction, material handling and agricultural equipment. PF427NC series hose has an orange, non-pin pricked cover, ideal for use in applications where a non-conductive, high pressure hydraulic hose is required. Typical applications include: hydraulic tools, lubrication lines and man lifts.
Kuriyama of America Inc., (847) 755-0360, www.kuriyama.com
