Pneumatic tubing
Oct. 9, 2012
Superthane pneumatic polyurethane tubing allows quick and easy line identification. Designed for air lines, it is naturally flexible for close-in bending — and with no leachable plasticizers used. It resists kinking, abrasion, and temperatures as low as –90°F (–67°C), while it handles working pressures up to 135 psi at ambient temperature. It is more resistant to pressure and vacuum than corresponding sizes of PVC or rubber.
Superthane Pneumatic resists attack from moisture, humidity, and fungi and is available in red, blue, yellow, green, orange, black, white, and gray, plus clear.
NewAge Industries Inc., (215) 526-2300, bit.ly/hp1012newage
