Hand crank and motorized HP1125 series reels include an upgraded swivel for high pressure applications. They are rated for operating pressure to 5000 psi, in 1⁄2- and 3⁄4-in. models. External fluid path configured with an electroless nickel plated steel 90° full-flow NPT swivel inlet.
Hand crank and motorized HP1125 series reels include an upgraded swivel for high pressure applications. They are rated for operating pressure to 5000 psi, in 1⁄2- and 3⁄4-in. models. External fluid path configured with an electroless nickel plated steel 90° full-flow NPT swivel inlet. Features include a sturdy one-piece, all-welded “A” frame base for maximum stability, low profile outlet riser, and open drum slot design to provide a non crimping, flat smooth hose wrap.
