RAM-5SF Speed Feed gun, combined with company’s Blue Nylon Brushes, cleans tubes up to four times faster than most rotary tube cleaners. As the cleaning tool loosens debris, shaft casing provides a steady stream of water, flushing out debris ...
As the cleaning tool loosens debris, shaft casing provides a steady stream of water, flushing out debris and restoring system efficiency. It controls direction of shaft rotation and flow of water; variable speed function controls brush speed and feed rate.
