Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 70641 Mr Oprods02 00000046160
Contamination filters
Sept. 5, 2007
DirtCatcher elements are outside-in flow elements with an outer shell that prevents contaminants from falling back into a system during element changes. They provide better pleat and seam stability than inside-out design because dirt loading occurs in ...
DirtCatcher elements are outside-in flow elements with an outer shell that prevents contaminants from falling back into a system during element changes. They provide better pleat and seam stability than inside-out design because dirt loading occurs in compression rather than tension. Excellement synthetic media offers low pressure drop and high dirt retention. Single or double length K-sizes are interchangeable with KZ and KKZ elements. They can be used individually or incorporated into RT, KFT, KF3, KF8, and KT filter assemblies.
Schroeder Industries, (724) 318-1100, www.schroederindustries.com
