Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 18202singlepng 00000011276
Single-pass filter kit
June 5, 2006
The 3K9 single-pass filter kit features three K9 filters mounted in series as a single assembly to provide in-line single pass staged filtration or particulate and water filtration. Each filter is rated for flows to 100 gpm and pressures to 900 psi. ...
The 3K9 single-pass filter kit features three K9 filters mounted in series as a single assembly to provide in-line single pass staged filtration or particulate and water filtration. Each filter is rated for flows to 100 gpm and pressures to 900 psi. Testpoints in cap or block record pressure readings and take fluid samples. Schroeder Industries, (724) 318-1100, www.schroederindustries.com
