Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2008 80331hydraulicf 00000052783
Hydraulic Filter
May 14, 2008
Duramax HNK filter for mid-pressure applications features 5-um Synteq XP filter media for high efficiency, high dust holding capacity, and long life. Dualpurpose design gives choice between spin-on or bowl cartridge style without changing ...
capacity, and long life. Dualpurpose design gives choice between spin-on or bowl cartridge style without changing heads. It is rated for pressures to 500 psi, static burst pressures to 1000 psi, and offers flow ranges to 35 gpm. It is rated for 1 million cycles, 10 G input at resonance frequency. O-ring seal provides reliable sealing without having to torque to specification.
Donaldson Co. Inc., (952) 887-3131, www.donaldson.com
Filter Elements in Hydraulic Filtration: The Key to Efficient Hydraulics
June 22, 2022
Selecting the right filter for an application will ensure proper performance and efficiency of hydraulic systems.
How To Buy Hydraulic Filter Elements - The Right Way
Feb. 14, 2017
When comparing filter elements, the better filter is the one that will achieve and maintain the required or targeted fluid cleanliness level (at the lowest cost).
