Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 11825prod0101jp 00000005405
Fluid contamination monitor
Oct. 7, 2005
PML2-W in-line fluid contamination monitor uses particle counter calibrated with ISO11171 for accurate and repeatable measurement of water saturation. Also measures fluid temperature. Designed to work to 400 bar working pressure. Results can be converted ...
PML2-W in-line fluid contamination monitor uses particle counter calibrated with ISO11171 for accurate and repeatable measurement of water saturation. Also measures fluid temperature. Designed to work to 400 bar working pressure. Results can be converted to PPM if oil type saturation and/or temperature characteristics are known. Features remote display module, and is PC/PLC controlled.
MP Filtri USA Inc.,
(215) 529-1300,
www.mpfiltriusa.com
