Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 45418 Mr Oprods02 00000020939
Drum topper filters new oil
Feb. 21, 2007
FlowGuard drum topper is a small and portable filtration station that acts as an off-line filter by removing dirt and moisture. It mounts directly on top of a drum and features an incorporated pump. It features an aluminum frame, two-stage filtration, ...
FlowGuard drum topper is a small and portable filtration station that acts as an off-line filter by removing dirt and moisture. It mounts directly on top of a drum and features an incorporated pump. It features an aluminum frame, two-stage filtration, clear PVC with steel wire reinforced hoses for visual confirmation of product flow, and differential filter gauges to indicate filter condition.
Des-Case Corp., (615) 672-8800, descase.com
