Magnom in-line magnetic filters are shown installed on the hydraulic fan drive circuit of a Caterpillar D-11 dozer. The motorâs supply line is at right, and the return line is at left.
Results from the tests quickly led to a cross-section of our customers to incorporate the Magnom filters into their machines. These Dozer operators have a keen sense to keep all their equipment operating efficiently, which led to the use of Magnom filters in a wide variety of equipment.
Today, with three to four years of maintenance cost data for the hydraulic systems from a study group of Cat Dozers, the Whayne Technology Division is able to quantify a significant reduction in hydraulic system maintenance expenses. Efficiently removing the very small particles of hard metal with Magnom filters has now been confirmed as a cost-effective way to reduce maintenance expenses by greatly reducing the instances of unscheduled system repairs or servicing.
Summary of tests
A group of D-6 and D-8 Cat dozers, used extensively in landfills, was selected for study. Magnom filters were added to the existing filter systems on some of the machines, while others—the control group—used only standard filters. The wide variation of loads, uneven terrain, dirty environment, and range of ambient temperatures make landfills a demanding application for this equipment. The annual maintenance costs for each machine’s hydraulic system was collected for a three-year period and analyzed.
All machines in the study group operated approximately 2,000 hr/yr and were provided with a standard schedule of preventive maintenance procedures, such as fluid analysis, spin-on filter change-outs, etc. Hydraulic system savings will vary based on hours of operation, operating environment, level of maintenance, and operator skill.
