Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 06 Cool Loop
Offline fluid conditioning system
July 11, 2012
Cool Loop offline filtration and cooling system conditions fluid and provides high heat transfer in a small size while limiting pressure drop. Compact, lightweight screw pump is quiet and provides max flow to 45 gpm.
heat transfer in a small size while limiting pressure drop. Compact, lightweight screw pump is quiet and provides max flow to 45 gpm. Filters consist of a standard 10 µm fiberglass element or optional 3, 6, or 25 µm fiberglass cartridge element. It is rated for a maximum pressure of 250 psi, 300 °F (150 °C) without filter, 230 °F (110 °C) with filter, and maximum viscosity of 150 cSt or 320 cSt.
Thermal Transfer Products, (262) 554-8330, www.thermaltransfer.com
