Water-glycol fluids
June 10, 2008
UCON ADVANTA Hydrolube Concentrate produces water-glycol hydraulic fluid with high shear stability for extended fluid life. It provides high fire resistance while protecting equipment under severe operating conditions. Designed for hydraulic systems ...
UCON ADVANTA Hydrolube Concentrate produces water-glycol hydraulic fluid with high shear stability for extended fluid life. It provides high fire resistance while protecting equipment under severe operating conditions. Designed for hydraulic systems using vane, gear, and piston pumps, it can be used in high temperature and high pressure conditions. It reduces pump wear and does not form sludge and will last longer than conventional fire-resistant hydraulic fluids.
The Dow Chemical Co., (989) 636-5162, www.dow.com
