Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 09 01 2010 86287fluiddyejp 00000058892
Fluid dye glows bright red for easy leak detection
Sept. 13, 2010
Spectronics Corp., Westbury, N.Y., recently introduced Oil-Glo 50, a fluorescent dye that glows bright red to detect leaks in petroleum- or synthetic-based fluid systems. Oil-Glo 50 easily pinpoints leaks in hydraulic fluid, lubricating oil, ...
Oil-Glo 50 easily pinpoints leaks in hydraulic fluid, lubricating oil, compressor oil, engine oil, and gearbox oil. The dye is concentrated, so only a small amount is needed to mix with the host fluid for accurate leak detection.
Simply add Oil-Glo 50 dye to any oil-based system and let it circulate. The dye escapes with the oil wherever a leak occurs and accumulates at all leak sites. Scan the system with a Spectroline ultraviolet or blue light inspection lamp and the exact location of every leak will be revealed by the fluid’s bright red glow.
Oil-Glo 50 will not damage the fluid’s properties or the system’s components. The dye can remain safely in the system for periodic re-checks until the oil is changed as part of a preventive maintenance program.
For more information about Spectroline Oil-Glo 50 fluorescent dye, call (516) 333-4840, e-mail [email protected] or visit www.spectroline.com.
