Water-glycol fluids
Jan. 2, 2007
Quintolubric 777-46 and 777-68 water-glycol hydraulic fluids contain less than 20% water. Quintolubric 777-46 is fire-resistant to HFC-E, biodegradable, and has a low water endanger class. Quintolubric 777-68 can be used in any hydraulic system ...
Quintolubric 777-46 and 777-68 water-glycol hydraulic fluids contain less than 20% water. Quintolubric 777-46 is fire-resistant to HFC-E, biodegradable, and has a low water endanger class. Quintolubric 777-68 can be used in any hydraulic system designed for water-glycol fluid, and can replace petroleum-based and synthetic hydraulic fluids in certain applications.
Quaker Chemical, (610) 832-4000,
www.quintolubric.com
