Sensor monitors hydraulic oil quality
Wouldn’t it be great if you could monitor the oil condition of hydraulic fluid in real time while the equipment is running? RMF Systems, Waddinxveen, Netherlands, recently introduced its OQS Oil Quality Sensors. The OQS constantly monitors moisture, oxidation, contamination, acid build up, wear particles, additive breakdown, and other fluid characteristics. An accompanying display shows oil condition in real time, plus rate of change data and trends.
