Emmie.2 mobile, plug-and-play system removes more than 99% of all solid particles between 2 and 5 μm from hydraulic oil, and virtually all water. Based on high-speed centrifugal separation, it helps increase oil system reliability and extend the service life of the oil. Compact system includes separator, feed pump and control system, which is installed in a bypass system and operates continuously. It separates dust and other particles such as paint, metal, plastic or rubber components from oil — and removes water that causes additives to oxidize and decompose.
Alfa Laval Inc.
(215) 443-4104
http://bit.ly/HP811AlfaLaval
