Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 08 01 2011 87731oilinspect 00000060392
Oil inspection
Aug. 8, 2012
Oil sight glass is available in standard and high-temperature versions to constantly and easily monitor oil condition for debris and discoloration, as well as oil level. Both come in 1 and 3 oz sizes, with 14, 38 or 12 in. NPT brass nipples.
Oil sight glass is available in standard and high-temperature versions to constantly and easily monitor oil condition for debris and discoloration, as well as oil level. Both come in 1 and 3 oz sizes, with 14, 38 or 12 in. NPT brass nipples. Standard glass is made of commercial grade acrylic, is rated to 225 (1 oz) and 200 psi (3 oz), and operates in temperatures from 40° to 165°F. Hightemperature glass made of heavy-walled Pyrex glass, is rated to 225 psi, and operates in temperatures to 450°F. Both feature a brass drain valve.
ESCO Products Inc.
(800) 966-5514
http://bit.ly/HP811ESCO
