Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Usefulprod0201j 00000003173
Hydraulic oil
June 2, 2005
Synthetic tractor hydraulic and transmission oil is formulated with synthetic base stocks and additives to provide multi-viscosity protection in all weather and helps avoid seasonal fluid change-outs. Suppresses wet brake chatter. Oxidation ...
Synthetic tractor hydraulic and transmission oil is formulated with synthetic base stocks and additives to provide multi-viscosity protection in all weather and helps avoid seasonal fluid change-outs. Suppresses wet brake chatter. Oxidation inhibitors increase lube and equipment life. Seal and hose conditioners reduce oil leaking and blown hoses. Protects against rust and corrosion.
Amsoil Inc., (715) 392-7101, www.amsoil.com
