Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 09 Houghton Drum
Fire-resistant hydraulic fluid
Sept. 11, 2012
Cosmolubric B-230 vegetable oil-based hydraulic fluid has additives to enhance corrosion resistance, metal passivation, and oxidative inhibition. It is a Factory Mutual Approved fire resistant hydraulic fluid that protects personnel and property from accidental fire and may lower insurance premiums.
Cosmolubric B-230 vegetable oil-based hydraulic fluid has additives to enhance corrosion resistance, metal passivation, and oxidative inhibition. It is a Factory Mutual Approved fire resistant hydraulic fluid that protects personnel and property from accidental fire and may lower insurance premiums. Its high viscosity index (214) allows the fluid to be used at a wide temperature range and is compatible with polyol ester fluids for easy conversion.
Houghton International,
(800) 666-4684, www.houghtonintl.com
