Got varnish? We have answers
April 7, 2014
Many of today's hydraulic systems contain insoluble contaminants, which are too small to be trapped by filters — and too small to be detected by particle counting. This varnish formation is a serious problem that degrades system operation.
Varnish in hydraulic systems starts off as soft, insoluble contaminants that are so small  they pass right through filters and go undetected by particle counters. They collect throughout a hydraulic system and can eventually become varnish that causes valve sticking and other system malfunctions.
These insoluble soft contaminants caused by a combination of water, heat, and oxygen. The heat is caused by static discharge, a process discovered several years ago that damages a filter's center core. Now, with additional study, there is solid visual proof that static discharge occurs throughout the entire hydraulic system, causing the formation of tar and varnish and reduced system performance.
Read the whole story by clicking here.
