Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9842products020 00000003632
Motor and drive system
July 26, 2005
The Gemini hydraulic motor and associated drive system is constructed with the Compact CBP, which offers high speed and high output power — greater than 2700 hp. Through hole accommodates shaft or tube for fluids. Gearless, it mounts directly ...
The Gemini hydraulic motor and associated drive system is constructed with the Compact CBP, which offers high speed and high output power — greater than 2700 hp. Through hole accommodates shaft or tube for fluids. Gearless, it mounts directly to shaft without gearboxes, clutches, or foundations. System efficiency equals or surpasses electromechanical drives even at higher speeds.
Hagglunds Drives
(614) 527-7400
www.hagglunds.com
