Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 46125spotlight0 00000021316
Variable volume piston pumps
March 20, 2007
PCP4-47 piston pumps are pressure-compensated with avariable-volume design. They reduce heat, noise, and power needs, and are rated for flows from 3.8 to 47 gpm at 1800 rpm. They maintain constant pressure while matching system flow demands. ...
PCP4-47 piston pumps are pressure-compensated with avariable-volume design. They reduce heat, noise, and power needs, and are rated for flows from 3.8 to 47 gpm at 1800 rpm. They maintain constant pressure while matching system flow demands. Multiple controls are offered, including standard pressure compensator, load sensing, remote compensation, and solenoid on/off.
Hyvair Corp., (281) 259-7768, www.hyvair.com
