Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2010 85882 Hydraulicm 00000058532
Hydraulic motors
June 11, 2010
Edited By Mary C. Gannon F12 series of 150 cc and 250 cc bent-axis, fixed-displacement motors offer reliable operation at a wide range of speeds and rapid change in velocity thanks to special lightweight pistons and a sturdy timing gear design that ...
F12 series of 150 cc and 250 cc bent-axis, fixed-displacement motors offer reliable operation at a wide range of speeds and rapid change in velocity thanks to special lightweight pistons and a sturdy timing gear design that facilitates quick acceleration and deceleration without damaging the motor. They are rated for continuous drive speeds of 3200 rpm (150) and 2700 rpm (250), and can be used in open and closed circuit systems.
Parker Hannifin Corp., Hydraulic Pump Div., (937) 644-4532, www.phpump.com
