Titan size 1280 radial-piston, multi-cam lobe motors are available in 12 sizes from 80 to 3681 in.3/rev. They achieve speeds to 200 rpm and accomodate pressures to 5000 psi intermittently or 4000 psi continuously. The largest produces more ...
Titan size 1280 radial-piston, multi-cam lobe motors are available in 12 sizes from 80 to 3681 in.3/rev. They achieve speeds to 200 rpm and accomodate pressures to 5000 psi intermittently or 4000 psi continuously. The largest produces more than 244,000 lb-ft torque without gear reducers. They come with a hollow through-shaft, integral torque reaction lugs, and ripple-free torque output of 120-power strokes/rev.
