Hydrostatic pumps
July 11, 2006
PVWC closed-loop, hydrostatic axial-piston pumps offer low hp for high-performance applications. They are rated for peak pressures to 5000 psi and maximum continuous speed to 3600 rpm and offer theoretical maximum displacements from 0.66 to 1.35 ...
PVWC closed-loop, hydrostatic axial-piston pumps offer low hp for high-performance applications. They are rated for peak pressures to 5000 psi and maximum continuous speed to 3600 rpm and offer theoretical maximum displacements from 0.66 to 1.35 in. 3 /rev. Hardened cylinder surfaces running on a hardened valve plate with pistons on a hardened swashblock surface contribute to long operational life.
The Oilgear Co., (414) 327-1700, www.oilgear.com
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
