PVWJ open-loop, axial-piston pumps provide stability in low-to medium-horsepower industrial and mobile hydraulic applications. They come in three frame sizes, 10 displacements and deliver low-flow/high-pressure to low-pressure/high-flow ...
PVWJ open-loop, axial-piston pumps provide stability in low-to medium-horsepower industrial and mobile hydraulic applications. They come in three frame sizes, 10 displacements and deliver low-flow/high-pressure to low-pressure/high-flow ranges. They are rated for speeds to 3000 rpm, maximum pressure to 5800 psi, and maximum displacements from 0.66 to 7.94 in.3/rev. Six control types permit field interchangeability without disconnecting from drive or system piping.The Oilgear Co., (414) 327-1700, www.oilgear.com
