Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2011 87483 Bentaxismo 00000060104
Bent-axis motors
June 10, 2011
Bent-axis motors MA 125 and 108R bent-axis motors are suitable for use in open- or closed-loop circuits, with displacements of 7.65in.3 (125 cc) and 6.61in.3 (108 cc), respectively. They accommodate continuous pressures to 5800 psi, 6525 psi ...
Bent-axis motors
MA 125 and 108R bent-axis motors are suitable for use in open- or closed-loop circuits, with displacements of 7.65in.3 (125 cc) and 6.61in.3 (108 cc), respectively. They accommodate continuous pressures to 5800 psi, 6525 psi peak, and rotational speeds to 8000 rpm, depending on models. Splined shafts and keyed shafts are available for all models. A variety of port configurations is available for interchangeability with most common models. Accessories include flushing valves and speed sensors.
Hydro Leduc N.A. Inc.
(281) 679-9654
http://bit.ly/HP611HydroLeduc
