Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 18238hydraulic0 00000010326
Hydraulic power units
June 5, 2006
MPN compact power units contain the pump and motor in one housing. Sound deadening and vibration insulation reduce noise emission to 6 dB. Radial piston pumps achieve maximum operating pressure of 700 bar and gear pumps to 200 bar. Maximum flow of ...
MPN compact power units contain the pump and motor in one housing. Sound deadening and vibration insulation reduce noise emission to 6 dB. Radial piston pumps achieve maximum operating pressure of 700 bar and gear pumps to 200 bar. Maximum flow of gear pump is 315 lpm. Large filler neck and drain plug allow easy fluid exchange. Hawe Hydraulic, (704) 509-1599, www.hawehydraulics.com
