Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2011 87474speedreduc 00000060095
Speed reducers
June 10, 2011
Speed reducers The 900 series geared speed reducers can be coupled with orbital, radial-piston, or axial-piston motors. They feature 4-planet design for high torque and life, a hardened ring gear, and large bearings on output shaft. They ...
Speed reducers
The 900 series geared speed reducers can be coupled with orbital, radial-piston, or axial-piston motors. They feature 4-planet design for high torque and life, a hardened ring gear, and large bearings on output shaft. They are rated for maximum speed input of 3500 rpm and offer ratios of 5.25:1 (others are available upon request). They are rated for intermittent peak torque of 36,000, 47,000, and 62,000 lb-in.(4000, 5300, and 7000 N-m).
Young Powertech Inc.
(888) 465- 3561
http://bit.ly/HP611YP
