Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2008 78396variablejp 00000051035
Variable-Axial Piston Pump
Feb. 15, 2008
Series 32 variable-axial piston pump A10VO for upper medium-duty range offers efficiency, low noise generation, and improved controllers. It comes in nominal sizes 71 to 140 and maximum pressure of 4000/5000 psi. It permits higher ...
Series 32 variable-axial piston pump A10VO for upper medium-duty range offers efficiency, low noise generation, and improved controllers. It comes in nominal sizes 71 to 140 and maximum pressure of 4000/5000 psi. It permits higher rotational speeds and up to 3% greater efficiency while reducing noise levels by up to 3 dB. It resists suction-pressure dips, housingpressure peaks, dirt, and contamination. Two- or four-hole flanges available.
Bosch Rexroth Corp., (610) 694-8298, www.boschrexroth-us.com
